Rename or Add Area Type
76jsa
Message 1 of 16
76jsa
I have created new Colour Scheme Category.
When defining the scheme, by type of area, I cannot change the name value or add another one nor delete.
Any help?
Replies (15)
Message 2 of 16
Alan.johnson1970
Hi, can you attach a copy of your file?
AJ.
Message 3 of 16
Alan.johnson1970
Are you trying to change the room names?
AJ.
Message 4 of 16
76jsa
I cannot.
But I attached a screenshot.
Message 5 of 16
76jsa
Value in the first tab cannot be changed not even I cant add any others.
Message 6 of 16
Alan.johnson1970
If it is the room name you are trying to edit, you can do it in the plan view.
AJ.
Message 7 of 16
Alan.johnson1970
To add more rooms to the list, you can add more rooms in the plan view. (using room tool)
You should also be able to add more rooms to the list using the + icon (then tag new rooms)
AJ.
Message 8 of 16
76jsa
No.
I am working with Area - not rooms.
Attached is another screenshot, sorry for that Revit language, but there is Area Type (office, flat..) .
I want to rename this category, because each of it has a different colour in Colour Schemes. But I canntot add to this categories my own, dont know why.
Message 9 of 16
76jsa
This works for me okay - but it is a room.
I want to use and edit this in area - but it does not work.
Message 10 of 16
Alan.johnson1970
Select the room name in plan view
Change to what you want
AJ.
Message 11 of 16
Alan.johnson1970
you can change from room name to area from the colour dropdown
AJ.
Message 12 of 16
76jsa
ROOMS vs AREAS.
I need this setup as you wrote to me do for AREAS - not ROOMS (first image), because I am counting floor of the flats not single rooms.
In Scheme definion I want to have selected not Color - but Area Type.
But I cannot add or rename or whatever with that category (second image).
Message 13 of 16
76jsa
This does not add another option as in Rooms.
Message 14 of 16
Alan.johnson1970
OK now I see what you want.
You need to add "areas" either in the plan view or
in "edit scheme" change the colour to NAME and add new areas by name.
The new areas will need naming by selecting the area and in properties select the new area name from the dropdown.
AJ.
Message 15 of 16
76jsa
thanks a lot for patience 🙂
this works and in the end i added my own parameter.
Message 16 of 16
Area Type are hard-coded, cannot be modified. You just need to use another parameter such as Name or Comments.
