Morning guys,
This example is MEP but its more of a general tag question
So i'm making some tags for our template over here. and i would like to, if possible, remove the gap between the size and the units:
The tag is simple, its just a size label
I've looked in the tag family and the project at the usual places (like those outlined here) but cant see a way
is it possible?
any ideas?
Morning guys,
is it possible?
any ideas?
Can you post your tag family - mine does that by default.
Really? Well that's interesting, might mean its a project setting then.
It's attached.
It's attached.
I can't see the attachment.
Strange, excuse me, attempt 2?
I don't think that you can change that unless you create your own tag. My example shows a tag that I created.
I know this is very late, but I figured it out, revit is kinda weird, so the workaround is to put no units under, project units, in the relevant section and edit the label to have a suffix, in this case mm or m.
Really? this has bothered us for a while thought there might be a legit solution..
thanks mate, will keep looking
