removing railings in stairs
Message 1 of 13
hello, I have created a stair in revit and the railing is generated automatically.  Please bear with me on this as ive not really used the stair function much over the years.
My problem is i need to remove a section of the railing (at the end of the landing as it is at the door to the building) but it keeps giving me the message "The Railing line must be a single connected Sketch. If you want separate pieces of Railing, create two or more separate Railings."
I think i know that it cannot remove the railing because it is hosted to the perimiter of the landing, but i cannot get a work around for this one =(
I was thinking doing the handrails all manually but that seems like a long workaround!
If anyone has any ideas I would be grateful.
Thanks, Jon
Replies (12)
Message 2 of 13
Edit sketch and remove segments until you are left with a single continuous string.  Finish.  Add railing attached to the stair again and repeat edit sketch to create the rest.  You may need to do it several times depends on how broken your railing are.
Message 3 of 13
Hi, thanks for you response. Are you saying there are lots of small gaps due to the railing being broken? So I can remove the bit I don't want at the doorway and then fix the broken gaps (in a 3d view?)?
Many thanks,
Jon
Message 4 of 13
No. What I am saying is you have to create a separate railing for each continuous string of segments. If you you need to break a railing at a door, you need two railings.
See screencast:
 https://knowledge.autodesk.com/community/screencast/74921759-6ad4-497a-a822-050702785040
Message 5 of 13
You cannot close out of sketch mode because you have overlapping sketch lines.
Message 6 of 13
Thanks again, I will try this over the weekend and let you know. 14 hr day today.
Many thanks for your kind help.
Jon
Message 7 of 13
Hello, I gave this a shot today and it would not work - I think because my stair is a kind of double switchback stair meaning that all the sketch lines are overlapping/on top of each other. Doing the method suggested it was not working, trying to delete some of the lines and leave others in is impossible when they overlap because you do not know which one is which.  It is looking like it needs completely put in manually - fine for the landings but the flights will not tie in aspart of the continuous sketch line (stair1.pdf) meaning the need to be done separately, which looks terrible
Please note that this is a bog standard stair with no modification at all.  Also when you create this stair from scratch an error appears saying the lines overlap,  I have pasted the message that appears when finishing the stair initially - I assume this is cause of the problem.
I did try the method you kindly suggested and this works fine for this type of stair.
Many thanks for your assistance with this one, it is greatly appreciated.
Cheers, Jon
Message 8 of 13
Sahay_R
Can you create separate pieces of railing? I did try to cut the railing with voids, then with void families - no go.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 9 of 13
Can you share the Revit stair?
Message 10 of 13
Why don't you just do the upper landing as a separate? Blow the landing out of the first stair sketch and it will get rid of the it's railing as well. Then you can just add segments to the existing railing to wrap the new landing as desired.
Message 11 of 13
Hi, thank you so much for your response. It is a standard u shsped/switcharound stair that has 3 flights. I will put a copy on tomorrow at work. Many thanks for your patience with this.
Cheers, Jon
Message 12 of 13
Hi thanks, Yeah that will do it I think for this circumstance. Not sure about the handrail joint at the interface, I'll give it s go in morning. As i haven't used the stair function that much in revit I was just wanting to do it as a one to include the top landing. I put this post onto make sure I wasn't missing anything obvious!. I've done steel stairs previously using individual beams & columns (I'm civil structural) so I wanted to give this a try and see how it went !
I can't thank you all enough for your comments.
Cheers, J
Message 13 of 13
Edit the existing rails to wrap the new landing, and you shouldn't have an issue. You'll be adding to a continuous rail.
