I have a structural model built in Revit 2018.
I also have mesh in .obj and texture in .MTL + jpg files for textures.
How can I import the mesh or a point cloud or something 3D from my OBJ and MTL to Revit model?
I have been searching a lot, except for mesh import that only imports mesh cant find anything else.
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Try importing the OBJ to 3DS Max, and from there to Revit
Could you shed some more info on this? like what format from Max to Revit?
I have an .obj and .MTL file. I imported the obj file to 3ds max and I changed the path to access my .MTL file. However, when I export this 3ds max file to DWG file, the material is not exported. Therefore, when I try to open DWG file in revit, it shows the object without any material. Could you please help me?
