Has anyone found a way to delete imported categories that appear in the visibility/graphic overrides dialog box?
Chris
Chris
My search brought me here guys. Apparently, I had this same issue regalith had even now in Revit 2018!
For people still struggling with this, our options are limited:
1 - If the dwg was linked, find and remove it from Insert > Manage Links.
2 - If the dwg was imported but not as "Current view only", find it manually in your model, delete it, then do a Purge Unused.
3 - If the dwg was imported as "Current view only", find and delete it from its parent view, then do a Purge Unused.
My model had more than 200 views with lots of view-specific DWGs so it was extremely tedious to do (2) and (3). These hours I can never get back ...
Ended up using this addin called Dwg Explorer to deleted DWGs directly from Imported Categories:
https://apps.autodesk.com/RVT/en/Detail/Index?id=3030640795772631843&appLang=en&os=Win64
There are similar ones out there so have a look around.
Hope this helps!
Hope this helps!
