remove unused parameters
bozandilistan
bozandilistan
Hi all,
I want to remove unused/double parameters from my worksharing model. is there any easy way to do it? i mean to check which one is using which parameters unusing? thank you.
Also sometimes i can export a parameter, but sometimes this button is inactive. why? is it about project parameter/shared parameter difference?
You're in a pickle. There's no "easy way" to do this. Rushforth Tools may provide you with some assistance though. http://www.rushforthprojects.com/
You can only export Shared parameters and only if you have a Shared parameters txt file defined for the project or the family.
