Remove 'negative symbol' in RELATIVE Spot Elevation
Hi.
I've made a relative spot elevation symbol/marker to denote setdowns in our slabs.
It works perfectly fine apart from the fact that the value is shown as a negative. I would like to remove the '-' symbol prefix from the value.
Unit settings won't override this, and as it's not a parameter I don't believe I can make a formula to cancel it with a double negative.
Does anyone have any smart ideas?
dferreira-blackwell
Just add Solid White region, If the family is editable or add solid white region in section or elevation to hide it.
kunalwadhera
Since it is by default there in System family, i don't think we can somehow change it.
But i do use Generic annotation in such cases.
I have attached a family in which you can write the value you want to display, and of course it will not have a '-' sign.
Cheers
