Remove Add-In
Remove Add-In
Message 1 of 10
Remove Add-In
how do I remove an Add-in.  The name does not appear in the windows add and remove programs list.  It is called KCL CADalog.  Seems to slow down the "big R" functions and I want to get rid of it.
Replies (9)
Message 2 of 10
Steve,
Some user specific addins are located within the %UserProfile%\AppData\Roaming\Autodesk\Revit\Addins folder.
The alternative location for addins for all users is C:\ProgramData\Autodesk\Revit\Addins\
If both the *.addin file and the associated *.dll files are in here you should be able to delete it, otherwise the *.addin file if opened will indicate the location of the dll.
Hope this helps.
Message 3 of 10
perfect. that worked.
Message 4 of 10
PaulFrancoisStorm
Instead of deleting it, change the extension to something Revit will not Recognize *.addoff, for instance. THen it will not load when revit is started. You can always toggle it on by changing it back to *.addin and restarting Revit. A real pity that Revit does not have an interface to exclude these tabs (like with their User Interface Options), as they can take over the ribbon.
Message 5 of 10
yes, very helpful. thanks
Message 6 of 10
This still works in Revit LT 2022.
I tried to install the Nicety addin: https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=200809200165377
Each time I open Revit the add-in asked to open? But not able to use in Revit LT - same problem in Revit LT 2021 and Revit LT 2020
Message 7 of 10
Jason_Miller6
CTC tools was my culprit for Revit 2022. I went here C:\ProgramData\Autodesk\Revit\Addins\2022 and changed CTC-BIM-Project-Suite.addin to CTC-BIM-Project-Suite.addoff. And DYnamo worked fine.
Message 8 of 10
Lehtinen5BZBJ
At least some add-ins' installers includes an option to remove the add-in from the computer. For example Autodesk Forma.
Message 9 of 10
tasherrill
I don't have any add-on plugs in my Revit. I still keep getting the Revit encountered a serious error. The current action could not be completed every time I try saving/syncing. I open a new sheet and purge everything before transferring only my electrical components, then save. I'm experiencing the same issue. I even rebooted my computer, but that didn't help either. Does anyone else have ideas for this? It locked my job up.
Message 10 of 10
tasherrill
Never mind, it was a component I had added to my job that was corrupted. I removed it, and now I can save and sync again.
