Reloading DWG position
jeanettephann
jeanettephann
Hi guys,
When reloading a DWG (which I haven't moved position in AutoCAD), I realized its shifted in Revit. How do I get it to reload in the same position? Thank you
What is the drawing for?  If it is a site plan then you can acquire coordinates from it after located it at the correct position.
You probably moved the Survey Point while clipped. If you move the Survey Marker while clipped, the Survey Origin moves with it - along with any Links that are using it.  If you just want to reposition the Survey Marker, then unclip it first.
