ReInstall Issues Revit 2017
Hi, I have a student license for Revit 2017. I had to uninstall Revit 2017 due to computer problems. However now when I try to reinstall, the files will download but the installer tells me that the files have already been installed and I can't go any further. Please help, I need this program ASAP. Thank you!
S.Jebakumar
Hi @Anonymous,
Try to install after deleting the Revit 2017 folder from program files.
:\Program Files\Autodesk\Revit 2017
also try to clean up the registry if it doesn't get installed.
Jebakumar
Jebakumar
BIM Specialist
ennujozlagam
@Anonymous hello, you can use autodesk uninstall tool to uninstall autodesk products. clear all your temp folder in your c drive those cannot delete just skip and try to install Revit again. you can download from autodesk virtual agent HERE. thanks
