referenced PME file visibility issues
Message 1 of 18
I have a PME consultant's file referenced into mine, and 1st floor ductwork is showing up in my 3rd floor RCP (as well as 2nd floor RCP).  The ductwork is modeled in the right place, so any idea why this would be happening?  I've tried playing with the view range to no avail.
Replies (17)
Message 2 of 18
Is the View Discipline set correctly?
Message 3 of 18
I've tried Coordination, Architectural, and Mechanical, but it doesn't change what ductwork and pipes are showing up in the view.
Message 4 of 18
Are you sure it's aligned properly.  Post the files. Let's see what's going on.
Message 5 of 18
syman2000
Change your detail from course to fine. See if the duct show up. Often the duct in course view won't show anything.
Message 6 of 18
it'll show a symbolic line/stick symbol in course view.
What about underlays. Got any?
...what a minute. I'm getting side-tracked here. I thought the issue is that the duct work in showing on the wrong level.
Message 7 of 18
Can you tell me what View's Associated Levels are? Under the View Properties.
...and View Range Settings.
Message 8 of 18
The detail level is set to fine.  They are showing up full dimension (not line drawings).  The issue is that the same ducts (1st floor) are showing up on all three floors.  The PME model is in the right position, as when I cut in section I can see it.
Message 9 of 18
I wish I could, except our company's privacy policy wouldn't allow.
Message 10 of 18
Associated levels are correct (2nd floor for 2nd floor RCP, 3rd floor for 3rd RCP, etc.) - View ranges are set in a way that shouldn't include the 1st floor ductwork.  Quite the puzzle!
Message 11 of 18
Can you post some screenshot at least?
Message 12 of 18
syman2000
Do you have link to view set for PME model? Sometimes I encounter users placed in RCP to show consultant MEP model but they reference to Level 1. So upper level may show the same layout as Level 1.
Message 13 of 18
Sure, here are screenshots of the RCPs for all 3 floors
Message 14 of 18
Is the consultant's file a CAD file?
Message 15 of 18
It's currently set to *Custom, <None> for linked view.  See attached image.
Message 16 of 18
Nah, it's Revit.
Message 17 of 18
Guess what, you got it!!!  I checked the linked view display settings under the 2nd list item (which I still don't understand why it puts it in there twice).  I changed it from 1st floor mech RCP to None.  Thank you!
Message 18 of 18
Boy, this is a booger. So, alignment is NOT the issue? You've checked the Linked Levels Elevation View?
