Reference Planes Organisation
Message 1 of 13
Hi all. I am using some reference planes for work in progress in a separate view.
I don't want this reference planes to mess with all views etc..
Which is the best way to keep them under control and organised?
Thanks in advance.
Accepted solutions (4)
Replies (12)
Message 2 of 13
constantin.stroescu
I use two way of control for Reference Planes:
  •  I create Subcategories of Reference Planes
  •  I use Named Reference Planes
Constantin Stroescu
Message 3 of 13
dferreira-blackwell
What I prefer is make a workset just for ref. plane turn off the workset globally from workset Dialogue box. Open the view you are working in press vv/vg-->Worksets tab-->override the ref plane workset from global to show in this view.
Message 4 of 13
@dferreira-blackwell @constantin.stroescu
Do you see any conflict using subcategories for the reference planes and at the same time putting them in a workset?
Thanks in advance.
Message 5 of 13
dferreira-blackwell
I don't see any conflict in that approach.
Message 6 of 13
how do you template/filter the reference planes once they are in a different subcategory?
Once in filters you can chose reference planes but not subcategories..?
Message 7 of 13
RobDraw
I would avoid using worksets for visibility. They are user assigned. Subcategories and a good naming convention is a much better option.
Rob
Message 8 of 13
@RobDraw @constantin.stroescu
the problem with subcategories is that you can filter them if they are all organised in subcategories, but what happens if you have reference planes that have no subcategory?
Help appreciated.
Message 9 of 13
You don't need filters for subcategories. Just go to VG of the views or the view templates and turn them off.
Message 10 of 13
@ToanDN @RobDraw
how do you turn off a reference plane that is not in a subcategory without turning them all off?
Please see my attachment regarding VG/anno ..
Message 11 of 13
@Anonymous wrote:
@ToanDN @RobDraw
What are you trying to show with the screenshot?
Message 12 of 13
@ToanDN See attached now
What I am trying to say regarding VG is that subcategories come under reference planes, if you have ref planes that dont belong to any subcatgories you cannot turn them off without turning all of them off..
Message 13 of 13
RobDraw
Put them on a subcategory of their own.
Rob
