Recreate a view callout?
PhilvK
Advisor Advisor
PhilvK
I previously created a view callout by windowing a portion of a ½”=1’-0” scale section so that I could also have a 1½”=1”-0” section detail. I still have the 1½”=1”-0” detail and the section reference exists in plan, but the view callout no longer appears on the ½”=1’-0” scale section. Is there a way to add it back to the section without starting over?
RevitRx
I'd check the ½”=1’-0” scale section's view properties first to make sure it wasn't hidden, or check the lightbulb to see if it was hidden inadvertently.
or
check "hide at scales coarser than" (you can access this in the view properties in the callout)
hope this helps
www.RevitRx.com
In case you couldn't find it, you can always create a new call-out and choose referenced other view, then point to the existing detail view.
PhilvK
Thank you RevitRx, but I did check these and the issue isn't any of those.
I'll keep looking!
PhilvK
And that is what I ended up doing. What I think happened is that after
originally creating the callout from the smaller scale section, I adjusted
the clipping limits on the plan callout, thereby somehow resulting in the
callout to disappear from the section. Thank you both for your replies.
