Recieved Error, drawings wont open
debbiebasta
debbiebasta
I am working in Revit LT.  The program was recently installed and has been working fine.  I believe all of my updates have been installed.  I received a display error message and my drawing was forced to close.  Now...I cannot open any other drawing.  See Screen shots below.
I did have an opportunity to send a report.  The report number is 327331367.
Thanks!
You mean you can't open or upgrade existing Projects - or do you mean you can't open a NEW Project?  If the latter, have you tried opening with a different Template (RTE)?
...okay, I see in one of your screenshots a reference to a missing Add-In.  Does that prevent you from Opening the Project?  If so, that's very odd. Install that Add-in and retry.
...Did you try Audit?  If not, open the Project again, but with Audit checked this time.
Audit a Model | Revit LT 2021 | Autodesk Knowledge Network
debbiebasta
After receiving the error while in a drawing, the program was not allowing
me to open any other files. It is currently working, but please record the
error number in case of any further errors.
Why would I "record" it?  This is a user's forum and I'm a user just extending a helping hand to another user.
debbiebasta
oh ok, thanks. Fingers crossed for no further issues.
