Recentralizing a model
When a consultant chooses to delete the worksets when detaching a file to be shared, it seems to remove the ability to make that model a central model again.  I can't seem to get it to be a central model again.  I have saved it to other computers.  The Worksets button is grayed.  The "make this a central file" button when saving is grayed.
What do I need to do to make this model a central model again?
Nardo
Go to Collaborate tab > click on Collaborate button then follow the instruction.
cbcarch
The file has lost it's central file path.
So,try doing Save-as onto your network file server, and rename the file.
Follow these steps:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
