Message 1 of 17
Recap Coordinate system shift/scale issue in Revit
06:37 AM
Hello everybody,
Using Recap 2017 4.2.2.15 and still have issues with coordinates shifting.
I'm trying to overlay two identical .rcp files in Revit, the only difference between them is that the second one has been cropped a bit in the outer border.
When I check the correspondence between them, I see a slight shift (about 9 cm) between the two identical spot. What happened? The scale is the same and should store the same survey base point.
Did someone experience the same problem?
