hi everyone.any ideas on how to construct a farrowing house design using revit? i have searched plans on the internet and i am having difficulties on how to start my plans.i have found out that it was a combination of concrete and timber (for trusses). i'll be grateful for any ideas that may help. thank you. God Bless everyone
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Decide on what you want the plans to be.
1) Start by creating walls - exterior and interior - doors, windows
2) Add in floor (I don't think that a ceiling would be required)
3) Add in the roof
Once you have gotten this far, then we can think about things like roof trusses, foundations, etc.
@barthbradley - in case you haven't noticed, I DID omit a ceiling. However, hogs do need some kind of terra firma to stand on. To the best of my knowledge. pigs still don't fly......
@nathanyiel - don't let the bickering obscure the preceding Words Of Wisdom!
Hi @nathanyiel
Hope that helps!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thanks to you, @Viveka_CD, I am now an authority on farrowing houses......
Viveka CD
@Viveka_CD: This is actually quite fascinating. I been spinning off your links into a plethora of information on the subject from around the world. And, you know what, @Sahay_R: they do have floors and ceilings! Also, the Danish have building codes that govern their design/construction! Who'd have thunk!
I'll suggest constructing the entire building envelope out of exhaust fans.
HA! I actually came across a "Mechanical Ventilation Design Worksheet for Swine Housing"!
Hi @nathanyiel
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Viveka CD
good day ma'am @Sahay_R
i am very sorry for the late response. i've just read you reply today and i think i have created the farrowing house like what you have suggested. please refer to the attached image, or if you may allow, i will send the revit file, and suggestions are welcome. there's a lot of room for improvement on my work, especially on roof and trusses.
thank you so much ma'am @Viveka_CD. if you will allow, i would to hear from you any suggestions/ideas about the farrowing house that i have created. attached are the images of my work. thank you very much.
@nathanyiel - looks good to me! Nice job!
Hi @nathanyiel
Looks good! ![]()
Thanks for getting back. Have you decided your materials for the structure?
Viveka CD
thank you ma'am @Sahay_R and ma'am @Viveka_CD
i've been thinking if i can replace the support of the roof. i've watched tutorials from youtube about roof trusses and managed to follow along.here's what i have created. but i want to make the rafter steel structure from wooden structure. also i want to know if there's any way i can make my custom steel truss.
Hi @nathanyiel
Try the trial Rafter Framing for Roof Models in Revit®*
Metal Framing Rafter+ lets you quickly create full rafter systems in Revit® models for light gauge steel frame roofs of any shape or complexity.
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
Viveka CD
