Realistic View not operating correctly
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
mumarshad
2595 Aufrufe, 8 Antworten
Hi Everyone
When I select the Realistic view my model it displays as transparently why ??
Give a solution to my issue and get back the correct realistic view of my model ( See the Figure the I Attached)
8 ANTWORTEN 8
Nachricht 2 von 9
Ilic.Andrej
als Antwort auf: mumarshad
Open up "Graphic Display Options" (you will find this in 3D view properties dialog). Under "Model Display" tab, check transparency slider.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 9
Either the walls use a transparent material or the walls category is set to transparent.
Nachricht 4 von 9
mumarshad
als Antwort auf: Ilic.Andrej
Hi Grozozo,
I checked the transparency of the model as you said, but there nothing to change the slide (It already set to zero value)
please help me to get rid of this issue!!!
Thank for your support!!
Nachricht 5 von 9
mumarshad
als Antwort auf: ToanDN
I'm having a problem with realistic view in my model,
When Select the Realistic view all the model will not appear as realistic view and some part of model appeared as realistic view ( See the Picture that I have attached)
Please,  help me to clarify this issue
Nachricht 6 von 9
chrisplyler
1. You have already checked the Transparency slider.
2. Also check for any category overrides in Visibility Graphics.
3. Also right click a transparent item, click Override Graphics > By Category, and clear any overrides there.
4. Also check whether those transparent items are in the Existing phase, and if your Phase settings have overrides that might cause this.
Nachricht 7 von 9
Viveka_CD
Hi @mumarshad
Is it possible for you to share a file with us to troubleshoot further?
Were to able to try the resolution suggested by @chrisplyler
Also, please make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Looking forward to your reply update.
Nachricht 8 von 9
klaude.lania
als Antwort auf: Viveka_CD
Hi all.
I have better problem. When modifying elements in realistic view such as trim, align move etc the Revit elemnts go transparent and stay that way unless you click and seclect each and every one including their neighbours.  Whats up with that Revitors?
Nachricht 9 von 9
klaude.lania
als Antwort auf: klaude.lania
Ohh yes I forgot. Before you post another smarty pants answer like: ohhh have you tried this or that, ohh is your computer switch on or, ohhh what is your computer spec ohh maybe your graphic card is not compatible. The answer is Yes yes yes and all of the above yes again. My system is brand new top of the range with all bells and whistles. It is so powerful that when I press coffee button it grows legs and fetches me coffee. I could type on my machine why Autodesk Revit gets worse each year but the answer would probably embarrass all you Autodesk folks so I choose not to just to save you some dignity.
