- Mute
- Permalink
- Report
At my wits end here.
I am trying to use an "IF" statement to output a specific text string that i can use a tag to identify an object to a prefab worker in a 2 or 3 digit alpha numeric tag or label.
The item i am building is a strut/hanger family set to 1'-0" in length, joined to an all-thread length adjustable in 1'-0" increments. I want to use the All-thread length to determine which one of these identifiers 1A, 1B, 1C,ect which will = 1' strut 1' rod / 1' strut 2' rod / ect.
Ideally this formula would lend itself to further refinement to add the strut length in 6" increments to also be used for determining and outputting the correct 3 digit nomenclature.
My initial statement looks like this:
IF((Length_O_Rod/1')=1, 1A,IF(Length_O_Rod/1')=2, 1B,IF(Length_O_Rod/1')=2, 1C)))
I tried this for several hours. attempting to remove the "inconsistent units error, " The following i not valid parameter"
I have pretty much given up trying to solve this. I did attempt to generate a lookup table but Auto desk doesn't really give adequate instruction for a novice to understand what to actually do. So, unless one of you programmer types can come up with a solution that i can understand.I will have to rely on using 8 individual families divided into 11 different types to be tagged for exporting.
Thanks for your help before hand I think i have this set up to alert me to replies, I case i have messed it up dont get pissed cause i didn't answer a post. I will be back to it. OH, almost forgot, here is a snip it of my data if you wish to see what i am using for parameters.
Todd Bowen USN(Ret.)
