Re: View Range? Walls cut-off in Level 1
lysaghtassoc
lysaghtassoc
Kia Ora, Everyone!
Could someone possibly tell me how to fix this problem? I've added another existing hangar to this model, down on the bottom left, but for some reason, half of it is missing!
I've had a play around with the View Range option on Level 1 but none of the options help me.
I can see the full building on the Site Floor Plan and Level 3, but not the level I need to see it on! I can even adjust it through the 3D View.
Please help me, I'm feeling dumb!
Kind regards,
Jane
RDAOU
@lysaghtassoc
On the properties palette,
  • scroll down to Make Crop region Visible
  • Stretch the  boundaries or the crop region on the view and switch its visibility back off
If you do not want the view cropped at all...uncheck crop view (it used to crop views to fit/suit spa e on the sheet
lysaghtassoc
Thank you very much! That's done the trick
