How to create a sloped roof profile
mutturaj869
Observer Observer
mutturaj869
Observer
Observer
how to create this sloped roof profile to add truss system using arkance dock someone please help
[The subject line of this post has been edited by Community Manager because it was originally a reply to another thread and re-published as a new topic. Original: Re: Queries for Revit]
Ric_Weber
I don't use Arkance Dock, but I wonder... did you create that roof as one roof or two?  If one, perhaps try creating it as two separate roofs and create a truss system for each, or if as two, perhaps try creating the roof as one and see what happens.  Otherwise, as I don't know that tool you are using perhaps you might need to reach out to them.
Ric Weber
If this post helps you, please like it or mark it as your solution. Thank you.
My Ideas: https://forums.autodesk.com/t5/forums/recentpostspage/post-type/thread/interaction-style/idea/user-id/12292525
mutturaj869
Observer
Observer
I JUST NEED THIS ROOF WHICH IS SHOWN AS THIS LIKE REFERENCE PLANES OF ROOF HOW TO MODLE SOMETHING LIKE THIS ROOF WHICH JUST SHOWS LIKE REFERENCE PLANE
Ric_Weber
So what is in the picture is not a roof modeled in Revit? I thought you had already modeled the roof. I'm sorry.
If you use the outside walls to make the roof, then select the edges that have a slope it will build the roof for you. There are multiple Autodesk documents on how to make a roof as well as YouTube videos.
And please remember that typing in ALL CAPS denotes shouting and anger, so I'm going to assume that was just a mistake on your part. Also remember that the forums are for regular folks to get help from regular folks, so this is not an official technical support/help method.
Ric Weber
modestas_vievesis894Q5
Observer
Observer
Please take a look at the video below. I show you how the roof was created. You first draw Walls using Revit, then Roof, with needed slopes on top of the walls. Then you can successfully start creating Trusses with Arkance tools.
