Underlay
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
afiejtek
5777 Aufrufe, 9 Antworten
Underlay
Is it possible to customise underlay colour? Grey/black currently offered is not always obvious enough.
9 ANTWORTEN 9
Nachricht 2 von 10
alan.quinn
als Antwort auf: afiejtek
Currently black/gray are the only options. However, development is aware of this and is looking into ways of changing this feature.
Nachricht 3 von 10
ryan.duell
Unfortunately this is not possible.  You are limited to the Manage > Additional Settings > Halftone/Underlay settings.
You can specify the weight and pattern (as well as apply halftone)
Ryan Duell
Nachricht 4 von 10
dzanta
als Antwort auf: ryan.duell
this is not possible currently.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 5 von 10
sureshchotrani
Wellcome to the Answer Day:)
Underlay I understand as Background color, it is support in Revit 2016 prior version doesn't support.
In Revit 2016 you can change the background color via going to options
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 6 von 10
larrymp
als Antwort auf: alan.quinn
 While i respect the response and that it is not an option, I would hardly say this is "solved". There have been quite a few releases of Revit since this response and still no option... SMH.
Perhaps there should be a few other categories besides "open" and "Solved". Perhaps "In Development" for something expected to be resolved in the next two releases and maybe "Wishlist" for items that are further off.
Nachricht 7 von 10
charlesUYHXW
als Antwort auf: larrymp
It seems that the underlay mimics the line colour of the element in newer versions. I realized this because my underlay was coming out red. Change the Line colour of the element in V/G settings to what you desire and the underlay should change to.
Nachricht 8 von 10
rlooZD4VD
als Antwort auf: charlesUYHXW
show us the process?
Nachricht 9 von 10
haydenPNTDP
Any progress on this issue? Really wanting to see upper or lower levels in a different colour for clarity.
Nachricht 10 von 10
mpfeffe2
Using Revit 2021 here, but I think this should apply to previous versions as well.
If you want to change the color of the lines of an imported underlay do this:
Visibility/Graphics (type VG)
Imported Categories tab (should be the fourth to the right)
Use the drop down + symbol to open up all of the layers under the file you want to be in
Select the layers you want to change the color of
Select Override at the top of this list
Select the color you'd like to change to
Press Apply and Ok
If you want to change the color of your selected lines do this:
Select File on the top left of the screen
At the bottom of this list select Options
Select Graphics on the left (should be the third option down the list)
Change Selection and Pre Selection to desired colors
Press Apply and Ok
