Re: Generic Family
Re: Generic Family
Pinky_Job-VEC
Re: Generic Family
Pinky_Job-VEC
Hi All,
I created a generic family for no fly zone. But for some reason, I can't control or change the depth when I load it into main project. If anyone has any idea how to solve this, please do let me asap. I have a big deadline tomorrow and it would help a lot. I notice the depth set to 1'-0" when I extruded. IS that the reason I cannot change the depth. I am attaching the family here.
Thanks!
attached
Pinky_Job-VEC
@barthbradley: Thank yo fr your quick response. I cannot open this file since it's in 2020. I am using 2019.
do u think u can save in 2019 version. also can you let me know what you did differently.
syman2000
Here you go
Here is 2019 Family. The Family can now be sized (e.g. shaped) dynamically in the Project Environment via dragging Shape Handles, and/or by entering Dimension Values in the Parameter Fields.  Note that "t9" has been added and "t.length" is now a Reporting Parameter for overall length.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Pinky_Job-VEC
I have 1 more isssue with this family in regards to the graphics. I reduced the transparency of this family, but when I loaded it into the main project, It is solid and not transparent.
