- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently trying to write some office notes for Shared coordinates as it's something that comes up time and time again both in-house and with other design team consultants.
Typically for our Arch model we publish the coordinates from our site model. This way if the building needs to move we simply do it in the site model and update the location by republishing again. This all works fine.
However, looking at it from another consultants view point, they would typically acquire shared coordinates from our Arch model. At the first time of askign this works fine. However if the buidling is moved and you try to reacquire the shared coordinates Revit says it's already acquired those coordinates and doesn't change anything.
Back in 2012 Steve Stafford wrote in his blog about resetting by using a different,empty file and then reacquire again. Comments afterwards seem to inidicate that this was no longer required, but running tests here today I'm not seeing that.
So my question, is there an easy way to reset the Shared Coordinates in a file?
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
