RCP doesn‘t show in print
MF-AC
MF-AC
Hi everone,
I‘m working with Revit 2019. In my project I created ceiling plans to show the structural Elements nessecary for the floor plan. On a sheet I stacked the views to get the correct presentation. This way worked just fine, but somehow Revit has decided it‘s not going to do it anymore - now when I print a pdf the RCP is not printed.
Any suggestions what might be the Problem?
ennujozlagam
have try to install latest updates from autodesk and see if helps. or post some screenshot bor better understanding. thanks
MF-AC
After trying a lot of workarounds we found a solution. We swichted display mode from hidden line to wireframe and now its working again
bin
Maybe you should try Underlay.
