Raster Images Covering up model
Message 1 of 18
Good afternoon. I'm using REVIT 2015 and using a very old architectural drawing (TIF file) to build a new model from. However, when I insert the file it covers up any walls etc that I put in. Is there some way to set the transparency of the image? (I've tried moving it the back and that doesn't seem to do anything).
Replies (17)
Message 2 of 18
rodrigo.bezerra
Michael,
The answer is change the draw layer on Properties.
Regards
Rodrigo Bezerra
Message 3 of 18
Rodrigo,
Thanks for the response. Currently the Draw Layer is set to "background" but it's still hiding the walls
Cheers
Message 4 of 18
constantin.stroescu
if Rodrigo's answer doesn't help, then try to increase the View Range of the View both in Bottom and View Depth.
Maybe , when you have drawn your walls you've used Depth instead of Height....
Constantin Stroescu
Message 5 of 18
rodrigo.bezerra
That's odd... Michael, can you post a screenshot with your image selected? You may zoom in or out to "hide" the project, if you need. Another screenshot with one wall select would help to.
Thanks for adding, Constantin!
Regards
Rodrigo Bezerra
Message 6 of 18
Rodrigo,
Here are some screen shots - i've moved the TIF file over so you can see the issue.
Constantin,
I've checked and the walls were all done using Height.
Message 7 of 18
rodrigo.bezerra
Hi Michael,
Would be better if the second capture focused on Properties Tab either, but that's ok 'cause you already checked walls (depth or height).
You may wanna check Constantin's s suggestions... Meanwhile, I found two things odd in your pics. First, you're working with shaded view but I've already tested and it doesn't cause your problem. The second one, why are your walls halftone? Are you working through underlay view?
Regards
Rodrigo Bezerra
Message 8 of 18
Good question on the halftone - somehow my settings had changed with out me noticing it (guess I need more coffee) but when I change it normal that didn't seem to make a difference (see below). Also set it to wire frame as well.
Message 9 of 18
rodrigo.bezerra
Michael, gotta be honest... I can't figure it out. You may try what Constantin suggest, and in case it don't work, maybe try to convert your tiff to another format (jpeg or png) and reload into your model. It's a very long shot I even doubt that's gonna do any difference, but when all the obvious shots are fired...
Hope our colleagues can help you.
Regards
Rodrigo Bezerra
Message 10 of 18
Rodrigo,
Thanks for the assitance. I'll play around and see if I can find out anything else (I've tried Constantin's advice - no luck)
Message 11 of 18
Found the issue. In my floor plan properties I had discipline set to electrical instead of architectural. Once I changed it to architectural everything worked fine.
Message 12 of 18
rodrigo.bezerra
I would never guess that... Thanks for sharing the knowledge!
Regards
Rodrigo Bezerra
Message 13 of 18
arunag
Hi, Please check the Discipline in the view properties. This happens if discipline is set to anything other than Architecture or Coordination.
Since your walls are showing in halftone, I think its in different discipline. Change to Arch or coordination & check
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 14 of 18
aghis_no
I think that you have this problem because your display is set to wireframe.
Try to set it to hidden lines.
Nor sure ... but I hope it helps
Aghis
Message 15 of 18
Thanks for posting.
Message 16 of 18
ermiass
It seem that you have edited/cropped the view port; reset the crop and try it; it solved my issue in an Elevation View.
Message 17 of 18
lwhiteQMVX8
Community Visitor
Community Visitor
Thank you! This worked for me, nothing above applied to my scenario but reset the crop and now it's printing just fine.
Message 18 of 18
AlliedElectric
I had the same problem, and I was able to correct it by pinning the raster image, in my case a PDF, and the unchecking select pinned elements
