I am using Revit Residental Template for the sheeting and shoring of a future building.
I have incorporated the solider beams, tiebacks, and grade. Attached is a screen shot.
The outstanding item is showing the different steps to excavate the dirt.
How do incoporate 3 different phases of the site? See attached.
Phase 1 is from grade to 10 feet below grade.
Phase 2 starts 10 feet below grade. Then at the end, the site will be at a slope from 30 feet below grade to 10 feet below.
Phase 3 starts as Phase 2. but the ramp is flipped to the other side of the site. This is to get the complete site 30 feet below grade.
Thank you!
Solved by RDAOU. Go to Solution.
When I submitted this, there was an error. So I resubmitted and now there is two post! Sorry for the confusion. Cannot figure out how to delete it.
@Anonymous
The subject of the OP refers to Phasing but the description that came after somewhat makes me look towards Scheduling and Sequencing. So before elaborating I have to ask; how are you modeling the site excavation in Revit?
I am assuming that what you are thinking of is to have first surface as existing, second surface graded/cut to level X and a thrid surface graded to cut one side and fill the other
@Anonymous
Ok thats basic cut fill...I would see it as follows
I think this is what you are aiming for. (well it is the easiest)...see screencast
@Anonymous
Building pads are fine but they don't do the work of grading...grading is something and building pads are another (at least for me) although they both can do cut and fill if this is what you are aiming at?
Building pads for instance are also phase-able; but I would rarely use them unless they are there to stay and not to be demolished (if demolished; you get your fill back; moreover, it is not really a good practice...You do the sheet/pile wall, excavate and grade then comes a pad Phase is over...
If you are an excavation/infra contractor I would understand (maybe sometimes but not always) phasing the excavation the way you did; it is doable but for me I consider it as construction sequencing. I would rather keep the Revit phasing where it is and do the sequencing and scheduling in P6. To an extent, Phasing in Revit is related to time and schedule but it is not the scheduling/sequencing itself.
I am not sure what kind of example I can give to make it clearer...
The purpose of having 4 views 1 for each phase is just how I work with phasing...give a wider perspective and clearer picture; besides it helps one not to lose track of what came where and which went where...I also have the same for the
and project browser does get sorted by phase too...Switching phases and phase filters in the properties palette every time you want to check something can get messy, confusing and can cause errors and mistakes on 400mil Euro project ...even on a small project (it's tidy) Clients are fond of phases lol and when a request is issued so many time the contractor's rep ends up gazing at the screen
"wait it's here"...pause..."oh! no it's there"...pause... "ok wait...give me a sec I'll find it and bring it to your office"
If I would have gotten half a cent everytime I heard that...I would have been retired 10 years ago
I'm thinking I need to create a new Family.
One where I'll have a top elevation, bottom elevation, length, and angle.
