Ramps Phasing
Ramps Phasing
Ramps Phasing
I am using Revit Residental Template for the sheeting and shoring of a future building.
I have incorporated the solider beams, tiebacks, and grade. Attached is a screen shot.
The outstanding item is showing the different steps to excavate the dirt.
How do incoporate 3 different phases of the site? See attached.
Phase 1 is from grade to 10 feet below grade.
Phase 2 starts 10 feet below grade. Then at the end, the site will be at a slope from 30 feet below grade to 10 feet below.
Phase 3 starts as Phase 2. but the ramp is flipped to the other side of the site. This is to get the complete site 30 feet below grade.
Thank you!
When I submitted this, there was an error. So I resubmitted and now there is two post! Sorry for the confusion.
RDAOU
DUPLICTAED POST
Original post discussed on the following LINK ->>> http://forums.autodesk.com/t5/revit-architecture/ramps-phasing/td-p/6316486
Phasing is not same as construction sequencing...see reply to other post
My thoughts are to do each END sequence under a Phase. Unless there is a better way to do this.
Which post should I be looking at? I am not seeing it.
