Ramp showing on wrong level
tstewart
tstewart
How to remove ramp displaying on wrong level?
Replies (7)
Turn off Underlay for the basement view.
tstewart
It's on the 1st floor to Mezzanine level, although it's showing up in the Basement.
ennujozlagam
you can select the ramp and hide in view. thanks
The View Range Depth/Bottom is probably within 4'-0" of the Ramp.
tstewart
The ramp starts on the level above (Ground Fl.), so how can I determine the View Range depth from the Basement?
Did you turn off Underlay?
tstewart
That was it...turned off Underlay and it worked. Much appreciated!!!
