railing panel control
FinearcLtd
FinearcLtd
Does anyone know a way to control glass panel distribution in railing. See the attached picture and file to understand the problem I am facing. Not a new one, however, I hoped that version 2018 will bring a solution. Seems I was wrong.Capture.JPG
Kimtaurus
Panels (balusters) always have a fixed size, they don't adjust to the spacing or length of the railing.
If a glass railing is what you need, you can also make this with a curtain wall. Instead of using a top and bottom profile add mullions.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Railing panels created by Baluster panel must be of the same length. If you need flexible spacing, don't use Baluster panel, use a rail with a thin profile. If there are no slopes, you could use a curtain wall as well.
Viveka_CD
Hi @FinearcLtd
Please see the solution by @Alfredo_Medina the post HERE
Let us know if you were able to resolve the issue.
