Railing Hosted to Topography Error
BigPicture045
BigPicture045
Using railings to create road curbs. I am getting this error message often. Usually resolved if the railing is made shorter. Is there a setting that can cause the railing creation to not have these errors?
Something wrong with the Railing? Post a screenshot of the Edit Baluster dialog box.
...drill down on the Error Message. Press Expand>> .  What else does it say?
BigPicture045
No balusters used.
Profile is a 8" square.
You need a height.
What about a Top Rail in lieu of a Rail?
...just tested yours and it hosts to topo without issue.  What's the Error say under Expand>>?
BigPicture045
Still having railing issues. I've tried switching to a top rail and I'm still getting unreliable results with the error "cannot create railing". The image below shows a relatively flat piece of topo which gives me this error message.
Not sure why these railings for curbs are so unreliable.
BigPicture045
I've had better results after following Bin He's Tutorial. https://www.youtube.com/watch?v=2Kv3AuNoQnU
However, now I'm having some gap issues:
It appears to have a lot of up and down for a curb.  You may want to grade the region to flatten the bumps a bit.
