Just a student here still learning Revit. I'm using the Armstrong Ceiling FELTWORKS Open Cell Ebbs & Flow family. I'm trying to change the material within "edit family", but it will not allow me to rotate the entity in order to change the material on all sides. This causes the family to only be half-covered in the desired material, which shows in my 3-D view.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You don't need to rotate the model in order to paint the material. You jut need to rotate the 3D view. If the 3D view is locked then you can unlock it.
This one:
Why do you need to rotate it?
...you could use the Paint Tool to paint the edges/faces differently. Is that what you want to do?
