Im trying to make a rail with a baluster as a support, i want to that way becaouse i want to be able to target a specific baluster and do adjustments. However this works good in similar cases, but in this one it doesn't. This thick wierd handrail keeps poping up and i don't understand where it comes from. If i delete the baluster support the handrail dissepears with it.
Solved by BDMackey. Go to Solution.
Post the file.
Handrails or Toprails must have a sweep in order to be used. They can't simply have supports or terminations. If you look at the top the Profile is set to "Default" that is where this is coming from. You will have to include one of the horizontal sweeps that are in the Railing as part of the Handrail
