Railing doesn't follow the slope of the second run
daniel_poleac
Message 1 of 9
daniel_poleac
I moddelled this stair using two sketched runs and one sketched landing in between them.
Now, the railing is able to follow the first run without a problem, but in the case of the landing and second run, it won't. I have also tried modelling it in two separate stairs, without a better result.
Do you have any suggestion on how to fix this?
Thanks!
Replies (8)
Message 2 of 9
jay_colc
it’s quite a complex arrangement so you may need  to break the railing into parts so it associates better with its host.  Using the split tool on the railing where the new run starts Revit creates new railing attached to the host by default, then you edit the railings on the landings.
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
syman2000
Railing doesn't like crossing with other line if you are dealing with slope. So I would break the railing at the intersecting line
Message 4 of 9
Try adjusting the Railing's Offset from Path distance. Inward.
Message 5 of 9
daniel_poleac
Thank you for the tip!
It looks like it's going to work out. I split the stairs into three runs and broke the railing like you suggested.
Message 6 of 9
daniel_poleac
Thanks!
Unfortunately, I needed it to be offset and match the railing above.
Message 7 of 9
No you do not need to break the stair into 3 runs.  Share the stair here I will show you how to do it with one run.
Message 8 of 9
...one more:
Message 9 of 9
daniel_poleac
Here is the stair. Thank you!
