- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using Revit 2024.2, our project has a railing (copy-pasted from a consultant's file) where "Baluster Family" in the Main Pattern is set to "None," and a baluster family is selected for the Starting Post and End Post. Per the documentation this should result in a railing with a start post and end post and nothing in between them, but when Revit generates the railing it has balusters (same family as start and end posts) in between spaced at 4'-0". In a plan view, these balusters can be individually selected, and if selected, they are pinned. They can be unpinned and moved along the plane of the railing, but if re-pinned they jump back to their original location. I actually want the Main Pattern balusters, but I want to change the spacing, and there seems to be no way to access them in the railing dialog, I can only unpin them and move them individually, not really an acceptable "solution." What am I missing here?
Michael Evans
