Rail - segments showing up in plan
7 REPLIES 7
Message 1 of 8
425 Views, 7 Replies
Working in RVT 2018, I've created a rail hosted to a ramp about 30' long. The rail is showing break lines / segment lines in plan even though the rail is drawn as a single sketch line (not drawn as multiple segments).
Why is it doing this; how do I get rid of those lines?
7 REPLIES 7
Message 2 of 8
Are those balusters?
Message 3 of 8
in reply to: ToanDN
@ToanDN there are balusters at those locations, but they (should) stop at the bottom of the top rail element.
Message 4 of 8
Wild guess #1: It's a Baluster penetrating the Top Rail every few feet.
Message 5 of 8
Ah ha! I guessed  it!
I'm feeling lucky now! I'm headed out to buy some Lottery Tickets!
Message 6 of 8
Look at the 3D see if they actually stop below the top rails.  If so, check VG see if Top Rails subcategory is off, or Railings category is transparent.
Message 7 of 8
in reply to: ToanDN
@Anonymous: What ended up being the problem?
Message 8 of 8
in reply to: ToanDN
There it is! Balusters set to stop at Top Rail element... with 1" top offset haha
With a 1" thick top rail, the 1"  top offset left the uphill side of the baluster submerged in the the top rail,  but the downhill side of the baluster poked thru, hence one line not two.
Thanks!
