Rail extension to baluster
p-jacobs
Message 1 of 11
p-jacobs
Hi all,
I've made a railings family with a top rail and some balusters with a baseplate. I want the toprail to extend back to the balusters. But it seems that it only extends to the bounding box of the baluster.
Yes, I know I can do that with tab selecting the top rail and modify the path. But that means that I have to edit the path for every instance of the railing twice (the other side is the same).
Is there a parameter or setting in the family that solves this issue?
Or is there something in the baluster family that I can adjust to solve this?
Replies (10)
Message 2 of 11
Edit Rail should get you there.
Message 3 of 11
p-jacobs
I know, but I'll have to do that for every instance of the railing separatly. I don't really feel like doing that.
Message 4 of 11
Ok. Gotcha.
Take care.
Message 5 of 11
Actually, post your file here.
Message 6 of 11
Perhaps not including the baseplate with your post, and model them as handrail support.
Message 7 of 11
p-jacobs
Hereby the example file. There are 3 options in there.
  1. The way I want to it to be but then with an extended piece of top rail as described above.
  2. The workaround. Using handrail 2 for the middle tube but then I get that cut line at the meeting point of the top rail and handrail which I don't want.
  3. I tried modelling the baseplate and post as separate family's. This works for the regular balusters. I added a post to the main pattern with an 'Dist. from previous' off 0. But this isn't possible for the start and end post.
Message 8 of 11
Out of curiosity, how long have you spent trying to find a workaround to using Edit Rail?
Message 9 of 11
Lachlan-JWP
Have a look at the attached file. I've built the railing return as part of the start & end balusters. This will allow you to make the change to all railing by changing the type properties and doesn't require editing the top railing.
Message 10 of 11
p-jacobs
I get your point.
But the thing is, it's a standard railing that is used all over the Netherlands by the national railway administration. So it's being used in a lot in projects. And it's definitly worth researching if it can be solved in a different way then using 'edit rail'.
Message 11 of 11
p-jacobs
Thanks for this solution, I haven't thought of that.
I'm gonna test this one out.
