RAIL & BALUSTER REFERENCE LEVEL NOT SAME AS RAIL REFERENCE LEVEL IN PROJECT
Ajay_J_S
Message 1 of 12
Ajay_J_S
HI I CREATED A SPHERE BALUSTER FAMLY AS SHOWN IN THE IMAGE AND ADDED IT TO PROJECT WITH RAILING.
THE PROBLEM I AM FACING IS THE RAIL CENTER NOT SAME AS BALUSTER CENTER AS SHOWN BELOW
I TRIED WITH CUSTOM PROFILE AS WELL AS THE REVIT DEFAULT PROFILES
APPRECIATE IF SOMEONE HELPS REAGRDING THIS ISSUE
Replies (11)
Message 2 of 12
kostask_oionei
What is the horizontal element? Top Rail, hand rail or rail? Does it have an offset?
Do you share a screenshot for that?
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Message 3 of 12
Ajay_J_S
HORIZONTAL ELEMENT IS THE INTERMEDIATE RAIL. BALUSTER SPHERE IS ON THE RAIL 1 STRUCTURE
Message 4 of 12
kostask_oionei
Does the intermediate Rail have an offset?
Kostas Kouris
Message 5 of 12
Ajay_J_S
hi this is the rail edit options & height
This is the baluster placement options. Both rail origin & baluster origin not matching the same place
Please help
Message 6 of 12
kostask_oionei
Check the Baluster Offset in Railing type.
Kostas Kouris
Message 7 of 12
Mike.FORM
Also, double check that the profile you are using for the rails "Circular Handrail1" is sketched with the centermark at the origin intersection in the profile family.
Message 8 of 12
Ajay_J_S
hi thanks for the reply I checked the edit type property. There is no offset value provided
Message 9 of 12
Ajay_J_S
hi i am placing the image of baluster i created & the rail here.
The image here is the baluster globe i created & also checked with revit's default baluster
The image below is the rail
In the project it looks like this
Message 10 of 12
Ajay_J_S
No proper solution found yet
Message 11 of 12
kostask_oionei
I didn't understand your problem correctly. I thought you were referring to some displacement in plan view.
From what I understand, however, you are referring to an elevation or a section.
Revit places the Ref. Level of the baluster at the top of the rail.
In the baluster family you can place a Reference Plane bellow the Ref. Level controlling the offset with a type parameter. Design the sphere with Work Plane the Reference Plane.
You can control the baluster height from this parameter.
Kostas Kouris
Message 12 of 12
Ajay_J_S
Hi thanks for figuring this out. Usually for any families we create the ref level of the family coincides and merge with the level of the project. When we load nested families component, the reference level & origin will merge or coincide with the other family. But this baluster doesn't seem to work that way. revits precision & accuracy is very low compared to other software. I would be difficult to create ref plance & offset to control the aligning based on the size & shape of baluster & rail family something going to top of rail without any means of eagerness is bad... Still need a solution without the ref plane & offset parameter
Anywat thanks for your valuable reply
