"There are too many elements missing in it"
my revit file is currupted and i tried all info to solve this issue so give me your email id so i can sent you file.original.jpe
nathan.chapman
vatsal-
Can you give some more information on what you have done to try to solve this?  Is this file workshared?  Does the file reside on a revit server, localy?  Any information will help us better troubleshoot the issue.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
I tried all methods given on autodesk suport website.
If you can send me step by step method that will be easier to solve my
problem.
vatsal patel
ennujozlagam
@Anonymous hello, you dont need to keep posting this issue so many times which already answered in your previous post. Only Autodesk technical support can help you with your problem and no one else in this forum, I tried whatever i can to help you but your files is corrupted. Just a quick question "are you a under autodesk subscription?. My advise to you is check your last saved files if have and modify from there to the latest file that has a problem. thanks
I have last file. It's running but I need that corrupted final file.
vatsal patel
john.vellek
Hello Vatsal,
I am afraid that I too was unable to recover your model. The error message indicates that there is too much file data corruption to ignore. You indicated that you had already searched the AKN for help and here is the main AKN Article I am sure that you have already seen that describes the issue.
I am glad that you have a working older copy that you can work from. I suggest that you run audit and resolve any errors that might exist in that file as well.
John Vellek
