hello autodesk support
one of my file cant open in my pc so kindly help me to solve that.
i have sent you that file in attechments.
thank you
Gelöst! Gehe zur Lösung
Gelöst von Jacob.westergaard. Gehe zur Lösung
@Anonymoushello you can try to check it HERE . hope it helps. thanks
i am not much familiar with revit im bigginer so if possible sent me your email id i can sent u revit file and if possible send me solved file
thank you
@Anonymous hello, i already PM you my email add. thanks
@Anonymous hello, im so sorry i cannot open your file. the file is corrupted. You can send this to autodesk technical support which they will be able to recover your files.
you can try HERE.
http://usa.autodesk.com/adsk/servlet/item?id=304463&siteID=123112
Thank you for taking your time to write this in the forum,
There are various reasons for file corruption, it's a general thing with all kinds of files. However, there are some areas that are more common than others, such as:
Having the latest version installed is important, for example throughout the lifespan of Revit 2015 we have 14 updates where each one of them contributes to a functioning product. So if you haven't already, I would check that every single user is running the latest version and this applies to all our products - the Autodesk Desktop App will notify you every time there's a new update - it will be the same for whatever release you may be using.
Note: Updating will not correct already corrupt files.
As to specific files, we would be more than happy to go through the files and correct whatever might cause conflict.
I would recommend everyone with these issues contact us as soon after the first error as possible, as it may become bigger with time.
Thanks again,
Best Regards,
Jacob Westergaard
Autodesk Product Support Team
Revit/CAD Specialist
