"?" on material tag attached to generic model
kanderson79WN3
Message 1 of 9
kanderson79WN3
"?" on material tag attached to generic model revit 22
Replies (8)
Message 2 of 9
Lachlan-JWP
Have you assigned a material to that element of the generic model?
Message 3 of 9
kanderson79WN3
Yes, I assigned the acoustic ceiling tile 24x24.
Message 4 of 9
Lachlan-JWP
Can you post the generic model & material tag family?
Message 5 of 9
kanderson79WN3
Yes, here is the files. These were created in 22 Revit and the videos for the class that this is coming from where 18 and 20 so I'm not sure if there is just a disconnect there.
Message 6 of 9
...yep, you have a Masking Region covering the Box. Remove it.
Message 7 of 9
Lachlan-JWP
Well, that was fun to track down.
There are 2 issues:
1) The generic model family has a masking region placed over it in plan view. When you use a material tag it will reference the material under the point of the leader. This allows you to use multiple material tags on 1 element. But when a masking region is used, it tries to read the material of the masking region but cannot find a value.
2) your material parameters are incorrectly assigned. In the family the material is using the "Box Material" parameter, but the acoustic ceiling tile material is applied to the "Box Material 2" parameter.
I've fixed those issues by deleting the masking region and re-assigning the material parameter.
I've attached the files below for you to have a look at.
Message 8 of 9
kanderson79WN3
Message 9 of 9
kanderson79WN3
OHHH that makes sense now thank you so much.
