"Inconsistent Untis" error when creating range based formula parameter
rsmothers11493
rsmothers11493
Trying to create an angle based family with ranges of angles. Every time I enter the formula it gives me "Inconsistent Units". I have tried the dividing by 1 and it does not fix.  Any suggestions?
Formula : if (cal_Angle < cal_Min_Angle, cal_Min_Angle, if (cal_Angle > cal_Max_Angle, cal_Max_Angle, cal_Angle))
Image:
rsmothers11493
Thanks for the suggestion. I have looked at these pages and actually this formula is based on that page of useful formulas. I have tried neutralizing it but this has no affect the error continues.
Post the file. I'll beat 'em into submission.
Alfredo_Medina
In your picture, the error message is hiding the value of "Angle". We can assume it is 115. But, is it 115 or 115°? in other words, is it merely a number or is it a degree?
It seems to me that it is a number, and that is why Revit says "inconsistent units" when you try to Apply changes; because you are dividing "Angle" by 2 and expecting that to be converted into the proper units for cal_Angle which is expecting a value in angles.
There isn't anything wrong with the long formula; the problem is in the short formula for cal_Angle. Therefore, the solution is this: For the cal_Angle parameter, enter this in the formula column: (Angle / 2) * 1°
