"IF" formula with "False reslut" get value itseft
Ar_vxv
Message 1 of 19
Ar_vxv
Hi!
Same like title. I try write If formula with false result by Input value ( not by  prevalue specify).
Is this possible!? Or another approach
For Examle: IF (H.1<110, H.2, <input value>)
With H.1, H.2 : the lengths of the two vertical sides
thanks for any help
Replies (18)
Message 2 of 19
I'm not clear what the "input value" is. Is it a value that can be computed?
Message 3 of 19
Ar_vxv
Hi!
if i don't use formula. I will have to enter smt in the value cell= <input value>
>>> IF H.1 not < 110, <False reslut> by my <input value>.
Message 4 of 19
Still unclear. What is supposed to happen if the formula returns "input value"?  Nothing?  Or do you literally want the Parameter feild to read "Input Value".   If it's a Text Parameter it could.
Message 5 of 19
Ar_vxv
when H.1 <= 110 . I use the value of H.2
When H.1 > 110. I want to enter numeric value in value cell
Looks like this is not possible in revit. So is there any other way in this case
Message 6 of 19
You cannot have a parameter that for input value and also reacts to a formula.
You need to add Input Value parameter:
d.2_input
d.2 = if (H.1 <110 mm, d.1, d.2_input)
Message 7 of 19
Look it; if H.1 is greater than 110, you are going to have to arrive at SOME value. Why can't that value already be computed and ready to use?
Message 8 of 19
Ar_vxv
can you explain d.2_ input more specifically:
I cannot enter d.2_input for Revit to accept.
which one do you mean:
-d.2_input
-d.2_100
-100
Message 9 of 19
-d.2_input
-d.2_100
-100
The formula: d.2 = if (H.1 <110 mm, d.1, d.2_input)
in plain English: if H.1 < 110 mm then use value of d.1 for d.2, if H.1 ≥ 110 mm then use value of d.2_input for d.2; for example if you enter the value for d.2_input = 200 mm then d.2 = 200 mm.
If you still don't get it, just share you family here.
Message 10 of 19
Ar_vxv
Thanks for help
Message 11 of 19
Message 12 of 19
Ar_vxv
-Why can't that value already be computed and ready to use?:
Currently, it depends on Sweep's position in the project. I will Duplicate the profile section and change the H.1 value to match. Now I want to add a function when H.1 <=110 then H.1 takes the value of H.2.
-Your image: 😄
Message 13 of 19
Revit 2022 family is attached.  I don't have Revit 2020.
Message 14 of 19
Ar_vxv
From that Formula i can understand. Many thanks!
Message 15 of 19
HUH??? That helped?  That's exactly what I've been trying to tell you all along!
Message 16 of 19
mhiserZFHXS
No its not. You had the if false result as a set value, not another parameter.
Message 17 of 19
No, that not what I was saying. Read Message #7 again.  I asked: "Why can't that value already be computed and ready to use?"  Where do ready-to-use, computed values come from? Other Parameters - that's where.
Whatever.  Obviously, we had a failure to communicate.
Message 18 of 19
Ar_vxv
@barthbradley
It's true! I should have seen such a basic thing. Pardon my ignorance.
Message 19 of 19
@Ar_vxv wrote:
@barthbradley
There's nothing to pardon. We just had a failure to communicate. I'm glad you reached an "Aha" moment. 😉
