"An unrecoverable error has occurred"
govinddev.r
Message 1 of 9
govinddev.r
This thing has been happening for a while, on both Revit 2016 and 2017 versions.
Its all updated, and add-ins cleared.
Even all the posts regarding this error have been tried but no use.
Please help, it's urgent.
Replies (8)
Message 2 of 9
ennujozlagam
Hello worse scenario is to clean uninstall and reinstall again the program and see if helps. Try to delete files in your c drive temp folder those cannot delete just skip. Thanks
Message 3 of 9
govinddev.r
Thank you for your reply.
I have already uninstalled and reinstalled both versions several times, temp files are also cleared.
But no use.
Same thing happening again.
Message 4 of 9
ennujozlagam
Try to refer to the link below and see if helps. Thanks
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 5 of 9
govinddev.r
Thank you for the reply.
The thing didn't work still.
I just tried all the options.
sucks.!!
Message 6 of 9
Viveka_CD
Hi @govinddev.r
Please look at the articles HERE and HERE for a resolution to this issue.
Let me know if any of the recommendations help resolve your issue, otherwise send us your recent journal and NFO file. Let me know if you have trouble locating these files.
Message 7 of 9
govinddev.r
Thank you, ma'am.
The software is fully updated, as well as option 2 is already done.
I've tried both of them.
No use.
Message 8 of 9
govinddev.r
Is that because I've'nt installed Revit 2018 version?
The Same thing is happening for both Revit 2016 as well as 2017 versions.
Message 9 of 9
performed the items shown.
Still receive fatal error pop up.
Does anyone else have a solution?
Thank you
