Quick way to disable volume calculations - a toggle, quick access toolbar or similar
HVAC-Novice
Advisor Advisor
HVAC-Novice
Is there a way create a quick access or toggle button to change the volume calculation on the fly without having to go into the settings?
I usually have volume calculations enabled since a lot of my design depends on that. But on a larger project it takes some seconds to re-calculate large room volumes when changing a rooms separator or similar. I noticed disabling volume calculations helps quite a bit. I'd like to be able to quickly disable volume Cal cautions if I do things not requiring volume calculations.
I didn't see a way to add this to the quick access toolbar.
(I know, a decent computer would help.....)
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
You can create a keyboard shortcut to the dialog but you still need to change it yourself.
HVAC-Novice
Thanks. that may be the best crutch to do this.
In an ideal world it would be a toggle that changes color based on status.
