Question: Annontate - Customized Tag
Hi, how are you?
A question with Annontate / Tags.
I created a new shared parameter (Project Parameters).
Is it possible for me to create a custom tag that shows this parameter?
This parameter is variable and is different in all categories / disciplines.
Does anyone have the workflow?
Yes. Create a multi category tag, add a label, add the same shared parameter to the label, load it in the project and start tagging.
Just curious, why do you need to assign the parameter to every category of the project?
Thank you very much. Now I know what I'm looking for.
I use this parameter for Navisworks Auto-Attach Using Rules.
But the construction is complex, I will use it to guide me in this project.
Multi-Category Tag can not be used in Tag All?
Really?Smiley Frustrated
