Question about the Split command
pierre_thibaud2
pierre_thibaud2
In Revit LT, I have made a wall and I have tried to use the SPLIT command button (see screenshot), but I don't succeed to set the distance indicated by the Split command. By example, how to enter 3.07 m (instead of 3.30 m in the screenshot) ?
mhiserZFHXS
What do you mean set the distance? Is this the regular split tool or split with gap?
Also, please stop starting new threads with incredibly similar topics. This seems to be a bad habit of yours. This could all be a singular thread about using the split tool.
AEC_Revit_Lab
The distance shown while Split Element is active is only a cursor readout, not an editable field. Place a reference plane 3.07 m from the wall end using a dimension, then run Split Element and snap to that plane. Hope this helps. If it solves the issue, you’re welcome to mark it as a solution so others can find it more easily.
