Queries Project Example in Dynamo
FarhanUddinShaikh
FarhanUddinShaikh
I am new i Dynamo, just wanted to know about:
1-can we insert parameter on property pallete,
2-once object created it will obey without Dynamo.
3-can it works on families creation
4-how can easily understand about their graphs
Any kind of project/family example can be a helpful.
Viveka_CD
Hi @FarhanUddinShaikh
Please check Dynamo Primer, a comprehensive guide to visual programming in Autodesk Dynamo Studio. Check this Resource for beginners
You can also post to the Dynamo Forum
See Dynamo for Revit—Baby Steps for the Non-Genius
Everyday Dynamo: Automating Simple Solutions That Bridge Workflow Gaps Within Revit
I've attached a pdf that explains Automating Simple Solutions That Bridge Workflow Gaps Within Revit
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
