Quantity of objects in a family
7 REPLIES 7
Message 1 of 8
crodriguezAFI
4224 Views, 7 Replies
crodriguezAFI
I'm new in using Revit, and I'm very interested in its Project Management properties.
I was wondering if there is some kind of report I can run to see how many objects are in a family in the entire project.
For example, the project is a big house, and I want to do a takeoff of all the different types and quantities of chairs used in the project.
I know there is a way I can see the quantity of objects in a project (bottom right corner). However in a BIG project this would take a big amount of time, and it's open to potential errors.
If some one has and option or an answer, I'll really appreciate it.
7 REPLIES 7
Message 2 of 8
in reply to: crodriguezAFI
Message 3 of 8
You have to create a Schedule/Quantity
Here is the sample for Furniture Schedule
Message 4 of 8
crodriguezAFI
crodriguezAFI
Thanks for the response. I manage to create a schedule, but as you can see in the picture, it is completely broken down and all my quantities are 1.
I can see on your sample photo, you have full quantities per family.
Thanks again for your help.
Message 5 of 8
Sahay_R
Sahay_R
In Schedule Properties - uncheck Itemize By Instance.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Rina Sahay
Message 6 of 8
Go to Format tab, select Count field and set it to Calculate total. Go to Total. Sort/group tab, group by Family field, uncheck Itemized every instance at the bottom. Add Count and Total under the same tab.
The link I gave you earlier should all the essential instruction on things you can do with schedules.  Spend some time read it.
Message 7 of 8
Hello @crodriguezAFI
Here's the sample settings for furniture schedule,
Message 8 of 8
crodriguezAFI
in reply to: ToanDN
crodriguezAFI
Thanks.
This finally got me on the right track.
Thanks.
