Quadro P2000 and LG Monitor with display issues
Hello everyone!
I'm not sure if this is the right forum to post. But since I use the hardware for Revit, I try this one. 🙂
I recently bought a QUADRO P2000 and an LG 34" UltriWide monitor. The screen, i get on the monitor has a resolution 1920x1080, istead of 2560x1080.
Monitor only has 2 1.4 HDMI connector. (Specs says 2560x1080, 75 Hz)
P2000 output is DisplayPort.
I'm currently using a HDMI to DP cable. It is deffinitelly not working. (When i set manually in the NVDIA settings with the custom settings, i'm able to get the required resolution, but width only 30 Hz.
What can be the problem here?
Read more about the same issue here. Sounds like you need a better DP to HDMI cable.
https://linustechtips.com/main/topic/444285-resolution-issues-with-displayport-out-to-hdmi-in-on-lg-...
P/S: I have the same monitor, luckily plugged to my laptop HDMI so it gets the full resolution natively.
Thank you! Yes, I have seen that post before, and yes it seems, I have the same issue.
That is a quite rare adapter, but I'll get it then.
